Hey folks, I've run into a little trouble with the '64, it's my daily driver and I'm riding the bus until the fix so any advice is wildly appreciated here. Here goes:
The rear end is in poor shape. It's a coil spring 12 bolt truck unit, 3:73 gears. Both axle seals are bad and the brakes need rebuilt. The brake work led to the discovery of all this other mess. So I was off to fix the seals, no big deal, peel off the diff cover and find this other gory mess. Looks like the pinion has slid forward into the carrier, so the carrier is all marred up and the face of the pinion gear is ate off, can't tell exactly how much but it looks pretty rough.
So I'm kicking around options and I thought I'd ask your opinions. Option (1)is a total overhaul of this rear end, including the brakes, axle seals and perhaps bearings, plus a gear swap. The carrier is ugly but functionally sound as near as I can tell. I don't really like this option because I'd want to hand the gear swap job over to a pro, and I think that might be costly. With everything involved, this sorta seems like the 'polishing a turd' option to me, even though I prefer to squeeze all the life possible out of original parts. Option (2)is a complete new rear end drum to drum. The cost of one of these would likely be comparable to the cost of repair to the old unit, and I could easily install it myself. I've already put out the wanted ad for anyone's used 64-69 rear ends in the swap meet. Can you folks through out some references for new or remanufactured units for me to price? I'd appreciate it?
Again, any thoughts or feedback is greatly appreciated, thanks!
