0 members (),
116
2
Mod | | | Forums66 Topics128,105 Posts1,056,541 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,835 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,835 | The flat rate trick on the fiber timing gears was to break the gear away with a pry bar, and then use a chisel over the keyway to remove the metal hub. A set of 2-jaw puller jaws with a little custom grinding will hook into the thrust plate bolt access holes and pull the metal cam gears. Yes a crank gear will split, but it takes a sharp chisel and a BFH applied with some energy to make it happen. There's usually enough room behind the crank gear to accomodate a 3-jaw puller if there are no bolt holes in it. We always used a metal gear, either aluminum or cast iron, as a replacement for the cam gear, and heated it so it was a slip fit over the cam snout. Just make sure to get the timing marks aligned on the first try, as you won't get a second attempt! Jerry
Entire Thread
cam gear , crank gear removal ?
| t5stang91 | 11/27/2009 5:53 AM |
Re: cam gear , crank gear removal ?
| atomarc | 11/27/2009 9:03 AM |
| truckernix | 11/27/2009 12:34 PM |
| t5stang91 | 11/27/2009 3:20 PM |
| truckernix | 11/27/2009 10:28 PM |
| atomarc | 11/28/2009 1:08 AM |
| truckernix | 11/28/2009 1:49 AM |
| hoyt | 11/28/2009 7:43 PM |
| truckernix | 11/29/2009 12:58 AM |
| Hotrod Lincoln | 11/29/2009 4:53 PM |
| t5stang91 | 11/29/2009 8:13 PM |
| atomarc | 11/29/2009 8:19 PM | |
