| | | Forums66 Topics128,109 Posts1,056,569 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The factory method of removing the crankshaft gear is great, if it is original. However, some of the replacement gears do not have the threaded holes for the puller. | | | |
Entire Thread
cam gear , crank gear removal ?
| t5stang91 | 11/27/2009 5:53 AM |
Re: cam gear , crank gear removal ?
| atomarc | 11/27/2009 9:03 AM |
| truckernix | 11/27/2009 12:34 PM |
| t5stang91 | 11/27/2009 3:20 PM |
| truckernix | 11/27/2009 10:28 PM |
| atomarc | 11/28/2009 1:08 AM |
| truckernix | 11/28/2009 1:49 AM |
| hoyt | 11/28/2009 7:43 PM |
| truckernix | 11/29/2009 12:58 AM |
| Hotrod Lincoln | 11/29/2009 4:53 PM |
| t5stang91 | 11/29/2009 8:13 PM |
| atomarc | 11/29/2009 8:19 PM | |
