1 members (1 invisible),
156
2
Mod | | | Forums66 Topics128,290 Posts1,058,562 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#59640 04/25/2006 7:29 PM | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | A quick and dirty check to see if there is gas in the float bowl is to look into the carburetor (ENGINE OFF ) while opening the throttle linkage manually. You should see a jet of gas being squirted directly into the throat of the carburetor as the throttle linkage is opened This is the jet from the accelerator pump. If there is no gas coming you have something obstructing the fuel supply. Could be a stuck needle valve obstruction in the fuel line, plugged filter, or maybe just a pile of junk in the float bowl | | |
