| | | Forums66 Topics128,109 Posts1,056,569 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If we are talking about a stovebolt here, the cam gear is removed in a press. The "crank gear" has two threaded holes if it is original. These are used with a puller. | | | |
Entire Thread
cam gear , crank gear removal ?
| t5stang91 | 11/27/2009 5:53 AM |
Re: cam gear , crank gear removal ?
| atomarc | 11/27/2009 9:03 AM |
| truckernix | 11/27/2009 12:34 PM |
| t5stang91 | 11/27/2009 3:20 PM |
| truckernix | 11/27/2009 10:28 PM |
| atomarc | 11/28/2009 1:08 AM |
| truckernix | 11/28/2009 1:49 AM |
| hoyt | 11/28/2009 7:43 PM |
| truckernix | 11/29/2009 12:58 AM |
| Hotrod Lincoln | 11/29/2009 4:53 PM |
| t5stang91 | 11/29/2009 8:13 PM |
| atomarc | 11/29/2009 8:19 PM | |
