| | | Forums66 Topics128,139 Posts1,056,758 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 227 'Bolter | | 'Bolter Joined: May 2005 Posts: 227 | I just rebuilt my 1960 Chevy C10 Master cylinder with the brake and clutch. The rebuild kit is the same for both sides.
I looked in the 1960 Shop manual on page 11-5 for help rebuilding the master. I noticed the brake side used all the parts where the clutch did not use the end rubber ring behind the return spring, nor does it use the return spring end.
Is this right?
1960 Chevy Apache (C10) 1965 Chevy C30 Dump Truck 1966 Chevy C30 Tow Truck | | |
