| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | It's not uncommon to get a stiff-turning shaft when the rope seal is first installed. It will loosen up somewhat as it runs. As long as the starter will spin the engine without excessive current draw, you're probably OK. Given these old engines' tendency to leak, a slightly tight new seal is probably a good thing! Jerry
