0 members (),
108
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Fried,
If you have a voltmeter make sure that DA#1 has zero voltage when the key if OFF.
How do you know there is a drain on the battery? Is it discharging or have you found a draw with your meter? Killing individual circuits by pulling fuses can isolate a circuit and narrow your search.
I believe some modern electronic gadgets like digital clocks or CD players may draw a tiny amount when energized...could this be what you're seeing.
A bum alternator can discharge the battery too.
Stuart | | |
