0 members (),
123
8
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I have a heavilly modified 261 using Jahns 10:1 pop up pistons and they fit the stock, except for porting, cylinder head easily, so your Venolia's should fit too. Because mine is more race then street, I'm using an older,not in production, Clifford mechanical cam from 1970! It has held up well. Patrick's could be an ERSON cam or DELTA cam, both very good. You might want to search there sites. Can't help with other questions as I'm using home made intake exhaust, but, Fenton's are good. I would stick with the new style Patricks sells unless you are looking for something more period correct.Then I would seach for the cast style.They are readily available.
Drew
Entire Thread
261 Engine rebuild questioms, pistons, camshaft.
| 37Chevy | 11/16/2009 2:16 PM |
Re: 261 Engine rebuild questioms, pistons, camshaft.
| DrewP | 11/16/2009 2:55 PM |
| 37Chevy | 11/16/2009 3:09 PM |
| DrewP | 11/16/2009 4:53 PM |
| bowtietim | 11/17/2009 3:31 AM |
| john1 | 11/17/2009 8:21 PM |
| Arpee | 11/19/2009 12:44 AM |
| bowtietim | 11/19/2009 3:53 AM |
| 1947six | 11/20/2009 4:34 AM |
| 37Chevy | 11/20/2009 3:58 PM |
| Greg_H | 11/21/2009 3:32 AM |
| tclederman | 11/21/2009 4:00 PM |
| Arpee | 11/22/2009 5:42 AM | |
