| | | Forums66 Topics128,196 Posts1,057,395 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#59215 04/15/2006 4:38 PM | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | "untill the push rod will not rotate" is too tight. when the engine as oil presure the hyd. lifters extend. easy way to find top on any given cyl. when the rockers are switching from intake close and exhaust open, the opposite end of the firing order will be at top fireing point.
"It ain't a truck if you can't hose out the cab."
Entire Thread
Thouroughly Confused (valves, lifters, rockers, blah, blah...)
| Colin | 04/15/2006 3:53 AM |
Re: Thouroughly Confused (valves, lifters, rockers, blah, blah...)
| Stovebold | 04/15/2006 12:59 PM |
| Chester | 04/15/2006 4:38 PM |
| truckernix | 04/15/2006 5:47 PM |
| Richard | 04/16/2006 12:32 AM |
| Colin | 04/16/2006 8:10 PM | |
