| | | Forums66 Topics128,092 Posts1,056,043 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | My 250 (from a '74 Nova) has the original "idiot light" switch under the thermostat. When I mounted the gauge, I put the sender in the left side of the head. The truck, '65 C10, has green & red lights on the dash, presumably for cold & hot, respectively. I've never seen the green light come on. I might have the wrong temp. switch?
cm If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | |
