Right, compare the wheel mounting surfaces, and confirm that the backing plates are in the neighborhood and fit outside the springs, usually not a problem.
If the wheel mounting surface measurement is off, consider what wheels you will use, might be you can still make it work with the right wheels.
Grigg
