General question with regards to a donor axle that I'm using for my 1961 Project Truck. My donor axle is approximately 3/4 to an 1 inch wider than my original axle. Will an offset in my rims make up for this if I go with a slightly deeper rim? i.e. 5 1/2 vice 4 1/2?
As always......thanks.....
The Project
