| | | Forums66 Topics128,085 Posts1,056,329 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Rick,
Are you talking about the front pan seal or the timing cover seal? Probably the timing cover seal which actually is the 'front seal'.
I don't know how technical you need the instructions to be.
Remove the pan, remove the radiator and crank pulley. Remove all the screws holding the timing cover on as well as the two bolts that go through into the crankcase area on the bottom of the cover. Pull the timing cover off and remove the seal.
Reverse this procedure to reinstall.
These are the highlights. I looked at the Keith Hardy's site for specific written instructions but couldn't find anything...more help will be on the way.
Stuart | | |
