| | | Forums66 Topics128,040 Posts1,055,478 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | GM transmissions of that era used to jump out of gear for two reasons in the transmissions. The shift forks wore out and the synchronizer assembly wore out. I grab every synchro assembly I find on eBay. 53 had 2 lugs and 54 up had 4 lugs. Did they replace these parts? A synchro assembly is about $125 and the forks about $25. A warped clutch housing or worn out pilot bearing can also cause them to jump out of gear. Of course the first thing to check is the simple things like linkage as mentioned earlier. | | |
