Originally Posted by red58
those stiffners are bent to align/square/flatten the hood and stress the crown so it doesn't flap in the wind so much - the factory tweaked each to suit the stamping, you'll find every TF has'em bent and none are quite the same ..... big mistake to straighten them out frown
That would explaing why mine are different from the posted pic. Mine is bent similar, only the bend is on the RR side of where the bars cross.
Bill Burmeister
