1 members (Shaffer's1950),
110
7
Mod | | | Forums66 Topics128,076 Posts1,056,009 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | The two clips kind of resemble the tabs on beer cans. They had a hole in them and were held in place by a small spring. I'm not sure if a spring that small is available at parts houses. A spring out of a retractable pen might work. If you loosen the wiper motor a little, you can twist it around a little and see what you are doing. The arms go on about a 3/16 post with a snap ring grove towards the end. This is where the tabs go and the spring keeps them in place by pulling against each other. | | |
