Ghostrider how did you make out with connecting the steering up? I cannot remember off the top of my head what the difference was between the 3/4 and 1/2ton Axle other than possibly bigger Brakes?
'47-'52 1/2, 3/4 and 1 ton axles should all use the same drag link.
To install your 1/2 ton axle in the 1 ton, all you should have to do is the same
procedure I described earlier for the swap I did.
