| | | Forums66 Topics128,284 Posts1,058,525 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#57951 03/19/2006 5:43 PM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Did you follow the cam break in procedure, 1500 RPMs for 20 minutes? If not a lifter can quickly develop a wear pattern that keeps it from rotating.
It could be the lifter is turning but the pushrod is tight at the rocker ball, stopping only the rod from turning.
See the USA in your vintage Chevrolet! My Blog | | |
