| | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I don't recall what the triangle and the lines are timing wise, but your est bet for setting the timing is to get a good timing light that has an adjustable advance knob on it. Use the timing ball to set it using the dial on the light to set the amount of advance you need.
Bill Burmeister | | |
