| | | Forums66 Topics128,042 Posts1,055,518 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I'd take the fuel line off going into the fuel pump and drain some gas into a glass jar. Hold it up to the light and look to see if its full of junk. Then just set it on the bench for a while and come back and see if the bottom is full of muddy looking stuff. This should tell you if you have a fuel problem, then you can start with going through the fuel pump and carb. | | |
