Originally Posted by b51r
to all: no gasoline dripping. Carter carb. 6 volt, same fuel pump as in old 216, correct size battery cables, cranks over slowly but draws down battery quickly, temp at or about 180 with a 165 thermostat,starter was out of another truck but was tested as ok.
b51r
<CLICK>
