9 members (3B, Bill Hanlon, JW51, 57 Drifter, Gdads51, Otto Skorzeny, Gray_Ghost, DennisM, rick46ia),
64
3
Mod | | | Forums66 Topics128,022 Posts1,055,362 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#57643 03/11/2006 6:01 PM | Joined: May 2005 Posts: 70 Shop Shark | | Shop Shark Joined: May 2005 Posts: 70 | Frank, Check the fuel pump. It might not be working properly and needs a little extra help from gravity. Sounds like you are having the problem when the fuel level in the tank gets to about the same level as the carb and gravity stops helping to feed the pump. This would happen if the fuel pump is getting 'weak' and doesn't have enough suction to pull enough fuel from the tank and pump it up to the carb without the extra help from the difference in the fuel level in the tank and the carb bowl. Could happen!!!
'52 Ted
illegitimi non carborundum
