2 members (Svcattle, baldeagle),
145
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,274 Posts1,058,432 Members48,489 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#57612 03/10/2006 4:31 PM | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | Resto44, When you put the top cover on you need to make sure the all three shift forks go into the correct slots on the main shaft. There are two positions on the main shaft and there is a reverse lever on the inside edge of the case. Also make sure the shift rods/forks move well on the top cover before you install the cover.
Jim
1954 GMC 1/2-ton Longbed 1971 Pontiac LeMans Sport
