| | | Forums66 Topics128,043 Posts1,055,614 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 208 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 208 | Chances are if the engine has sat for some time the valve seals could be dry which will let oil seep into the combustion chamber. If it doesn't clear up after a short run time you may need to replace these. It can be done with the head on the engine, but it can be a PITA.
When I've had this problem in the past (SBC) but they only smoked on start up. The seals let oil in when I let the engine sit overnight. Once the small amount of oil burned off at start up it was good. | | |
