| | | Forums66 Topics128,101 Posts1,056,180 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 461 | The condensor is the same for either system voltage; the size is determined largely by the primary windings in the coil. A usable dwell range is determined mostly by the number of lobes on the distributor cam and is independent of system voltage, so the 28-32 degrees is fine. Remember to set the ignition timing after setting the points- the point adjustment/dwell affects ignition timing.
Harvester | | |
