8 members (MikeE, Bucker, MickeyP, Rexville48, dt235sd, Forty9, David Bush, kades51),
89
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,702 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 122 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 122 | Finally got around to installing mast bearing. Denny you were right it took quite a bit of coersion with a hammer and socket. There was a considerable amount of the rubber that squeezed to the top. Once it was resting on the flange I used utility knife to remove excess rubber. I realize this part of the question turns electric but since Im here i figured Id ask. The wire coming off the bearing has a black wire with a round connector end and the the horn wire from harness is tan with typical flat connector. Do these two wires connect? If not where do they go? Thanks again, Brian M | | |
