Racecarl,use a master cylinder with the same bore as the original if using the stock drum brakes.A larger master bore will give you a firm pedal requiring more foot pressure,smaller bore ,generally a mushy pedal ,less foot pressure.1-1/8 is the stock master bore size on 51 and up I believe.The earlier Huck brakes used a one inch bore.
