1 members (Hotrod Lincoln),
61
2
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#57163 03/01/2006 11:12 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Grab the pinion flange. There should be no up-down play. Pull the cover & try to move the ring gear & carrier side to side. There should be no play there either. Get some gear marking compound & check the gear contact paterns. Compare it to the shop manual chart. If it is not right move the carrier in or out by loosening the adjuster on one side & tightening on the other. Keep experimenting till you get the best pattern than snug the adjusters up & put the locks back in. The amount of backlash is not important unless it is way out of spec. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
