| | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The width is pretty close to the same, and may be exactly the same. However, the surfaces you are bolting the crossmember to are not exactly the same. The various trucks I've measured have all been slightly different.
This IFS crossmember is bolted through the sides to the frame AND bolted through the bottom of the crossmember to the bottom of the frame.
The challenges are in the shape of the bottom of the frame where the crossmember needs to match up and be bolted on. The lower edge of the frame has a complex shape that on a 1-ton is not nearly close to flat. I don't know the exact shape of the smaller trucks, but would encourage anyone thinking about this swap to check it with a straight-edge before assuming this is a simple bolt-on swap. Also be aware most of the surface that needs to match at the bottom is ahead of the axle centerline.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
