| | | Forums66 Topics128,103 Posts1,056,188 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | You always have to be careful sand blasting sheet metal.
I would use sand blasting on sheet metal as a last resort, and or for the really hard to get to stuff. The big flat areas that are easy to get to are also easy to warp are best sanded with a sander by hand, not sand blasted. If after sanding you have small spots of rust blast them carefully.
I've been really impressed with soda blasting for sheet metal, removes everything but the rust. Faster, better, and easier, but not any cheaper than chemical striper.
Grigg | | |
