| | | Forums66 Topics128,128 Posts1,056,684 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#56930 02/23/2006 8:38 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Only new part I've been able to track down is the spring. They are usually a bear to get free. Usually heat and penetrating oil and time. Don't try turning the counterweight with pliers, there's a rivet through it that will shear off. Tapping the end of the shaft sometimes works. You can end up drilling out the rivets that hold the valve to the shaft to clean things up. Did I mention that it's not easy?
Fred 52 3600 69 C-10
