| | | Forums66 Topics128,049 Posts1,055,701 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Were it me I would do, in the following order (testing after each step to see if the problem is fixed): 1: Verify battery cable size as Tim mentioned. Replace if necessary. 2: Clean the battery cable ends (pay special attention to the ground cable). 3: Load test the battery. Replace if bad (the more CCA the better). 4: Test starter. Rebuild or replace if bad.
If you don't have it fixed by then you have larger problems.
