0 members (),
140
0
Mod | | | Forums66 Topics128,260 Posts1,058,343 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | 61 1/2 ton should have either 4.10 or 3.90 gears, iirc. Another factor is tire size, specifically the rolling radius, measured from pavement to the center of the wheel. You double that distance to get the tire diameter for the formulas. Cruising rpm for the stock 235 is 2,200 to 2,700 rpm. Above that for extended times and your rods start to stretch and fatigue. Here's one link to a calculator, there are a lot more out there. http://www.ring-pinion.com/calculators/calculatorsind.html
Fred 52 3600 69 C-10
