| | | Forums66 Topics128,178 Posts1,057,063 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I can see where there might not be enough resistance to work a flasher since there would be no brakelight bulbs before the converter as there would be if the box was used for it's marketed purpose. You might also try an electronic flasher made for LEDs if you don't have enough resistance. | | | |
Entire Thread
Combining the rear brake, tail, and turn lamps
| Toyvo | 08/19/2009 3:26 AM |
Re: Combining the rear brake, tail, and turn lamps
| tonkadawg | 08/19/2009 3:09 PM |
| Cletis | 08/20/2009 6:35 PM |
| Toyvo | 08/20/2009 11:20 PM |
| Cletis | 08/21/2009 12:34 AM | |
