Play around with gas flow 20 to 25 CF to much and You get cold weld to little and the weld will look bad and splatter and remember all gauges are a little defferent so Your gauge could read 22 CF and weld fine or it might read 26 and weld fine You just got to play around I set mine at 23 CF for sheet metal
Have fun, Pete
