8 members (Gdads51, Youngin' Tut 59, Phak1, Gray_Ghost, Leo, Oswald, Otto Skorzeny, 1 invisible),
125
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,137 Posts1,056,430 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#56581 02/16/2006 12:09 AM | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | Knox; 1. Pull all your plugs 2. Starting with No.1 or No 6 Cylinder screw in the compression gauge and take a dry reading from each of the cylinders 3. Make sure you write down the readings 4. Repeat the process, only this time, squirt a small amount of oil into each cylinder before you crank the engine. Approx. a teaspoon full 5. Compare your readings. - the dry readings should be lower than the wet readings, if not this could indicate bad rings - two cylinder next to each other indicate the head gasket is blown between the two cylinders - My 48-51 sop manual says compression should be about 110 Lbs. with all cylinders within 5-10 punds of each other
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | |
