| | | Forums66 Topics128,069 Posts1,055,886 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#56571 02/17/2006 7:43 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | 90wt gear oil, yes, till it starts to run back out the top [fill] hole - if you're going thru the adjustment slot, moving the outer end of the tool handle toward the center of the wheel expands [tightens] the shoes, to loosen, handles goes toward the tread
Bill | | |
