| | | Forums66 Topics128,060 Posts1,055,831 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#56508 02/18/2006 1:47 AM | Joined: Apr 2005 Posts: 187 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 187 | James The half ton springs will not fit. I used the springs from a Toyota,they have to be cut off with a grinder or torch and welded back on. 2nd-a one ton frame is straight and the 3/4 has a hump over the rear end,this would be best if you don't want your axle to hit the frame. tntrucknut
_____________ Floyd If we choose being kind over being right,we will be right every time. Knowledge is a poor substitute for experience. Remember what is precious to another, may not be to you, but it is precious nonetheless. 1948 Chevy 2-Ton | | |
