1 members (Jimmie D),
110
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Paul, More than likely, 3836848 is a head casting code (did it come off the head)? That codes was used on 235 heads from 1956 through 1962. You have a high pressure 235 engine (the valve cover tipped Denny off) - a similar cover was used from 54-63 on 235/261 engines. If you want to more specifically identify your block and head, post the codes that you find at the locations shown here. Tim | | |
