| | | Forums66 Topics128,091 Posts1,056,035 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#56440 02/13/2006 12:56 PM | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | So it is definitely a 1/2-ton Chevy rear-end then, not a GMC. Well it looks like my entire drive train is not original. Is there any thing note worthy about this rear-end good or bad? One thing I noticed when I had it out of the truck is when I turned the pinion shaft to check the ratio I was able to reach over and stop the axle from turning on both sides one at a time. This makes no sense to me. I would think the the gears would be coupled and if I held one axle I should be able to stop the pinion shaft from turning. The one thing I was not able to do, since I do not have three hands is to see if while I was turning the pinion shaft and holding on axle if the other axle was now coupled. Can anyone explain this to me? Thanks.
Jim
1954 GMC 1/2-ton Longbed 1971 Pontiac LeMans Sport
