| | | Forums66 Topics128,113 Posts1,056,277 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | That is true, 16.5s are getting very hard to get. Most tire shop don't even stock them anymore. We don't at the shop I work at. If the truck isn't a dual wheel model, 16" rims should fit just fine. Used to run around with a guy that had a '49 1 ton, that's what he put on it. Used 7.00-16 bias ply tires on it. If you're not 100% worried about an authentic look, I would suggest either a 235/85/16 or a 245/75/16, which are very easy to get.
Bill Burmeister | | | |
Entire Thread
advice,wheel choice '48 8L?
| 'muck' | 08/10/2009 12:42 AM |
Re: advice,wheel choice '48 8L?
| OldSub | 08/10/2009 2:15 AM |
| LONGBOX55 | 08/10/2009 2:35 AM |
| truckernix | 08/10/2009 2:53 AM |
| 'muck' | 08/11/2009 2:22 PM |
| 'muck' | 08/24/2009 12:56 AM |
| aggie jon | 08/25/2009 3:27 AM |
| LONGBOX55 | 08/25/2009 3:54 AM |
| Tailgater | 08/31/2009 3:03 AM |
| 'muck' | 08/31/2009 2:15 PM | |
