Ok. Truck is finally home in my garage. I have pictures posted on Facebook. Can I rephrase the question?
Is there a way to swap the torque tube rear end finnards for a more modern 3/4 ton carrier assembly, and if so, which one is it?
There are aftermarket modifiers for front axle ball bearings to roller bearings. It has no steering box, so what would also fit that would be a GM part?
1965 Olds F85 wagon
1969 Olds Cutlass
1965 Falcon Van
1969 El Camino
1972 GMC 3/4T
1972 K5 Blazer
1971 C10
1976 Suburban
1978 Suburban
1930 F**d AA Stake
1989 CK3500 2WD
2000 CK3500 4WD
1953 GMC 3100
1] *Note* All drawings are subject to engineering changes at any given time without notice of: barometric pressure, wind patterns, caffiene, or written authorization of the female.
2] Cash for Clunkers: You can have my truck, after it has turned into a pile of rust in the driveway.
