| | | Forums66 Topics128,196 Posts1,057,395 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Part 1: There is no back up light in a standard type tail light housing. If you want back up lights you will need a separate light. The 2 wires in your tail light housing are for brake/turn light and tail light. You need to determine which is which.
Part 2: Sounds like a ground problem. Grounding cab to frame may solve it as fenders may be isolated from frame ground but are bolted to the cab. If that doesn't solve it, ground the inner fenders to the frame. | | |
