| | | Forums66 Topics128,030 Posts1,055,418 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 156 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 156 | I have a single wire self exciting alternator on my truck as part of a 12 volt conversion. I have the idle RPM set at 500 and the Amp Meter is slightly negative. If I pick up the RPM's the meter swings positive. Do the RPM's need to be set at a higher idle speed for a self exciting alternator to work correctly?
Jim
