2 members (WarEagle1, 1 invisible),
172
6
Mod | | | Forums66 Topics128,284 Posts1,058,522 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 19 New Guy | | New Guy Joined: Nov 2007 Posts: 19 | i have a 63 C-10 with a 79 350 V8. i have had an oil pressure problem. when the truck is cold and i crank it up the oil pressure guage will max out 80psi is the highest it will go but it will pass 80 and hit on the stop at 0 (probably right around 100psi when it hits). after the truck runs for a 3-5 minutes and warms up the guage will go down and run around 50-70 psi at idle. what is causing such high oil pressure? another thing if i would give it any gas after i first cranked it up it would blow the oil filter seal out the side and start leaking oil. i am pretty sure the guage is accurate. Thanks YC | | |
