| | | Forums66 Topics128,127 Posts1,056,678 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Tom, Post the code that is pressed into the block in the ledge just to the rear of where the distributor enters the block. Someone here should be able to identify the size/year/application of the engine. Here are locations of other casting codes for high-pressure 235/261 engines. I do not know if these locations are the same on earlier 216s/235s (maybe someone will let us know if the locations are the same). Tim | | |
