Coils will work with the polarity reversed. However, as coils warm up, the windings expand. If the insulation is bad, the coil will stop functioning. If this is the case, replacing the coil is the only option. 6 Volt coils do not need resistors when used in a 6 volt system. Try a different coil and make sure the polarity is right.
