What 3B said. Valve actuation has absolutely nothing to do with the amount of power an engine is capable of. The bore/stroke ratio and dimensions, valve timing, valve size, combustion chamber geometry, volumetric efficiency, fuel quality, fuel/spark map and state of tune are what determines the amount of torque and engine produces
