| | | Forums66 Topics128,020 Posts1,055,345 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Slip a piece of hose over the stem and blast away. I wouldn't go with a lot of pressure. Leaving a rough surface it will cause problems because the carbon will stick to it better.
You could also soak them in lacquer thinner, it will soften up the varnish.
Fred 52 3600 69 C-10
